Why this convergence trend?
Old   July 6, 2009, 17:51
Default Why this convergence trend?
Edgard Espinosa
eespi002 is on a distinguished road
I am doing a 3D model with turbulence ( Realizable k-epsilon model) and I am using default Under Relaxation factors for the first 100 iterations. Then at 101 iteration mark, I switch to lower Under relaxation factors to allow the solution to converge. However, when I switch to lower URF number, the solution proceeds to diverge.
Can anyone explain why this is happening? How many iteration should I allows the solution to go through for a 3D model?
Any response is appreciated.
Pleas see link:
http://i1009.photobucket.com/albums/...onvergence.jpg
eespi002 is offline   Reply With Quote
Old   July 7, 2009, 02:17
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
it diverges (you get an error message) or you have a jump?
The jump is normal, if you let iterate, you should retrieve the convergence
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   July 7, 2009, 09:34
Edgard Espinosa
Thanks -mAx-.
I did get an error message. It states:
Turbulent viscosity limited to viscosity ratio of 1.0000000e+6 in 1cells.
Could this have a large impact on the convergence? Also, typically how many iterations should be given to a 3D-turbulent model?
Thanks in advance.
Old   July 7, 2009, 10:04
-mAx-'s Avatar
Maxime Perelli
this is not an error message, but a warning.
Let iterate, and check if the number of cells involved in this warning is decreasing (in your cas you just have 1 cell )
There is no typical number of iterations untill convergence.
Monitor a variable you want to compute (drop pressure, force , massflow or whatever) and iterates untill you get a flat curve. Then it means that this has converged.
Check also the residuals charts
Old   July 7, 2009, 10:54
Edgard Espinosa
Thanks again.
convergence, under relaxation factors
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 02:17
Problems with convergence with an easy system franzdrs Main CFD Forum 0 June 15, 2009 19:17
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 11:55
Defect correction and convergence ganesh Main CFD Forum 4 June 30, 2006 15:20
Convergence problems Chetan FLUENT 3 April 15, 2004 20:13
