June 23, 2009, 11:56 |
Rotating Arm Simulation
DT
Rep Power: 17 |
Hi everyone,
I am trying to simulate a sphere rotating about a point, submerged in water. I have defined a domain around the sphere as fluid. Now I proceeded to solve for the forces etc. on the sphere in the following two ways: Approach 1: At the Inlet, defined the fluid velocity as angular, of the appropriate magnitude, and with the apt rotation axis. All this in absolute terms. Approach 2: At the Inlet, defined the fluid velocity as angular, of the appropriate magnitude, and with the apt rotation axis. Also, defined the sphere as rotating about the rotation axis. All this in absolute terms. Could you please help me out over here and tell me which approach is correct? Would all the extra terms due to the circular motion (centrifugal force etc) be included in approach 2 and not 1? Please can anyone help me out with this? By approach 2, wouldnt the viscous force increase? Because the velocity of the fluid relative to the sphere will increase and become the (velocity of the sphere + Tangential velocity of the fluid) right? So does that make the first approach correct? Does it take into account the centrifugal forces too? Thank you in advance.. |
the rotating domain simulation | lius | Main CFD Forum | 3 | July 8, 2017 09:33 |
ROTATING TURBINE BLADE SIMULATION | Anant | FLUENT | 2 | March 31, 2011 11:57 |
modification for rotating cylinder simulation | zonexo | Main CFD Forum | 3 | July 21, 2006 15:24 |
Wind turbine simulation | Saturn | FLUENT | 1 | June 16, 2006 03:12 |
Stirred tank with baffles simulation using single rotating reference frame | M.Zhou | FLUENT | 1 | March 5, 2000 16:01 |
