Have one question, almost porous medium.
Old   June 18, 2009, 19:20
Default Have one question, almost porous medium.
Aleksey
lobzik is on a distinguished road
The fact is that I have to construct a certain mesh which describes some kind of porous medium. Let's imagine a numerical 2D (or 3D) array of cells. Each cell contains a zero or an one value. One means an active cell (the domain where fluid flows) and zero means nonactive cell (for example solid where fluid can not flow). In other words we have for example a tube and in this tube there are a lot of (thousands) fixed (nonmoving) solids. Fluid flows throug this medium. How can I mark the zero cells as a solid if I have simple square mesh?
lobzik is offline   Reply With Quote
Old   June 19, 2009, 05:18
Aleksey
Maybe I've explained rather difficult for understanding? What's wrong? Would you give me an advice concerning my issue?
Old   June 21, 2009, 22:33
Aleksey
OK. Now I've construct a simple cubical mesh. Also I know vertices of cells which should be deleted from this simple cubical mesh. I know how to do this in Fluent and Gambit (in Fluent this cell should be marked using "Adapt-region" and then using "Grid-Separate-Cells" we can separate this cell trom the rest zone and after that using "Grid-Zone-Delete" we can delete this cell; in Gambit we may perform boolean operations with faces or volumes). Now the question: how can I delete/substract thousand of cells from my simple cubic mesh? Or maybe to try another way using import option in Gambit to import my case in another format?
porous medium and reactions Valeria FLUENT 1 July 10, 2009 04:58
Thermal non-equilibrium model of porous medium Merlin CFX 0 October 19, 2008 02:51
Flow through porous medium Kiran AS Main CFD Forum 1 August 31, 2006 09:12
Heat transfer from porous medium to fluid Ralf Schmidt FLUENT 1 October 30, 2005 07:21
porous medium input - a question Shankar FLUENT 4 December 16, 2002 13:35
