Fluent-ANSYS Coupled Flow-structural Analyses
Old   June 17, 2009, 14:35
Default Fluent-ANSYS Coupled Flow-structural Analyses
Boris Vaisman
bvfluent is on a distinguished road
Ladies and Gentlemen, could you please advise is there a way to run a coupled simulation using Fluent and ANSYS? I am looking for a solution to map a Fluent solution (whole or partial) onto ANSYS and visa versa. I can go with either an ANSYS solution or a third-party implantation. Thank you very much. Regards, bvfluent.
bvfluent is offline   Reply With Quote
Old   June 18, 2009, 05:02
Default Workbench 2.0 / Ansys 12.0
mbernard is on a distinguished road
Hello
Check if the new version of ansys is available for you, because it allows you to use a one-way coupling between Fluent and Ansys mechanical quite easily.
Anyways, if you don't want to wait for the new version, i think there's a way to to the connexion between softwares called MPCCI.
Check out for this
Regards
mbernard is offline   Reply With Quote
Viscoelastic flow modeling in Fluent Ankur Navra FLUENT 3 July 26, 2013 06:56
FLUENT, flow past a circular cylinder Paul Reichl Main CFD Forum 16 December 8, 2012 16:21
FSI, Fluent Ansys coupling Greg Carnie FLUENT 5 January 7, 2010 20:15
Oscillatory Flow in FLUENT phy FLUENT 0 February 2, 2008 11:19
regarding reacting flow with coupled solver kiran FLUENT 2 April 15, 2005 05:57
