Problem with drag coefficient calculation
Old   June 12, 2009, 21:55
Default Problem with drag coefficient calculation
Crystal is on a distinguished road
I'm quite new to Fluent and lately I've been facing a rather strange problem relating to drag coefficient calculation. I'm trying to simulate external flow over a sphere at Re = 100, 300 and 1.1 X 10^6. My problem is: when I select air as my fluid, my results closely matches the reported values. However, when I select water as my fluid, my results are totally off, and the values are close to zero.
I've checked that I've keyed in the corresponding velocities correctly. I even tried changing the dimensions of the sphere and running on double precision solver to ensure it is not caused by limit in precision. But to no avail.
What could be the problem? Would really appreciate any help on this!
Crystal is offline   Reply With Quote
Old   June 15, 2009, 06:09
Ervin
Nectanebo80 is on a distinguished road
Hello
Be careful when calculating coefficients (drag, lift, moment, etc) with Fluent. It depend on your reference values. The defaults values are for air. Length=1m, Surface = 1m2, Viscosity of air, etc.. You'll have to re-multiply with your fluid and geometry values in order to obtain the correct values (report/ reference values)
Ervin
Nectanebo80 is offline   Reply With Quote
Old   June 18, 2009, 06:44
Hi Ervin,
Thanks for your reply. Anyway, I've found out that the cause was due to Fluent somehow not being able to accept the change in the Material Properties values. I exported the mesh file from Gambit again, and repeated the setup process in Fluent. This solved the problem :-)
Drag Coefficient for Ellipse Form (2D) Ketut Utama Main CFD Forum 8 December 11, 2014 12:03
Plot drag coefficient against Y(distance) edwin FLUENT 0 February 4, 2008 10:41
Need urgent help Regarding Drag coefficient srinivas FLUENT 3 September 20, 2006 11:10
Need urgent help Regarding Drag coefficient srinivas Main CFD Forum 1 September 16, 2006 15:15
Need urgent help Regarding Drag coefficient srinivas FLUENT 0 September 16, 2006 13:25
