exporting drag force from fluent
Old   June 7, 2009, 16:52
Default exporting drag force from fluent
fluentguy is on a distinguished road
I was doing an optimization problem using fluent and modeFRONTIER, which is an optimization software. This requires that the drag force (that can be got from report -> forces, in Fluent) be exported from Fluent in the form of a file so that I can import it into modeFRONTIER after each design iteration.
Is there anyway I can go about this? The export option sends structural force details of every node, which I do not want. I just want the force of a surface on the whole, as is given by the report -> force option.
Can anybody suggest something ?
Thanks much.
fluentguy is offline   Reply With Quote
Old   June 7, 2009, 23:34
Actually, it is quite easy. I failed to notice that we can write the result directly to a file and use this for the optimization process.
I have another question : when I try to run gambit in batch process, I have to use the dos command:
gambit -inp name.jou
But I keep getting the message : gambit is not recognized as an internal or external command, operable command or batch file.
Does anybody know how to fix it?
Old   October 27, 2009, 15:19
Default Update?
potrero is on a distinguished road
Did you find a solution to the problem with ModeFrontier and the dos command?
(gambit is not recognized as an internal or external command, operable command or batch file)
potrero is offline   Reply With Quote
Fluent no longer know their Drag vs. Re curves ? R. Koeman FLUENT 1 May 3, 2010 13:43
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 04:41
drag force in two phase flow Ken CFX 5 November 21, 2005 16:28
Exporting mesh from Gambit to Fluent Becky FLUENT 1 January 11, 2005 14:01
Airfoil Drag Force wowakai Main CFD Forum 3 October 13, 1998 20:27
