Dynamic mesh - structured mesh
Old   June 3, 2009, 16:40
Default Dynamic mesh - structured mesh
mrestrepo30 is on a distinguished road
I'm doing this 3D simulation which involves the movement of one of the walls of the object, and for this I'm using the dynamic mesh capability of Fluent.
Here I'm enabling smoothing and also the hex mesh smoothing (which worked perfectly for the 2D simulation). I'm also setting up all the adjacent zones to the moving wall as deforming zones, with smoothing and remeshing enabled.
However, when I start checking the displacement with "Mesh Motion" I can see that the mesh is not displacing what will cause eventually negative volumes. I used this same configuration for an unstructured mesh and it worked perfectly, but I don't know what extra parameters I should set up in order to have the mesh updating at every time step.
mrestrepo30 is offline   Reply With Quote
dynamic, mesh, mesh quality, mesh structured, smoothing
failure in dynamic mesh updating Fabrice FLUENT 2 June 12, 2006 05:57
dynamic mesh - structured or cooper mesh Manoj Kumar FLUENT 2 November 11, 2005 02:18
dynamic mesh and sliding mesh nasser FLUENT 0 November 1, 2005 03:37
Dynamic mesh & Multiphase Alexandre FLUENT 3 September 13, 2002 12:35
