How to find lift coefficient by fluent?
Like Tree7Likes
Old   February 4, 2011, 07:52
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Originally Posted by John222 View Post
Sorry but when you say different mesh faces do you mean the Sizing (maximum face size) I am using (car.x_t) geomtry file from Ansys.
and in the max face size by default its 1.78m.
can someone tell me the full steps of how to change mesh faces 10.000-20.000-30.000.
If I take your mesh picture, I assume you meshed it with tri.
Then you gave a element size, let say 1 for example.
You can refine your mesh by changing the value of element size (0.5 instead of 1).
Then remesh, export, etc...
I see you have local refinement in your mesh. If you used size functions, then you need to change the max size in each size function, instead of the value in the surface-mesh panel
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   February 4, 2011, 08:22
John
John222 is on a distinguished road
Please check the pictures of my coarse tri results. and the mesh too.
what do you think?
John222 is offline   Reply With Quote
Old   February 4, 2011, 08:47
-mAx-'s Avatar
Maxime Perelli
oh you are working with workbench...
So forget what I said previously (I thought you were working with Gambit)
I cannot help you on the meshing side since I only have Gambit.
But if you are interested by aero Coeff, I would apply Boundary Layer around your car (especially if your flow is turbulent >>Check lectures about first cell layer height & y+)
Also I wouldn't iterate with just 100 iterations: you can see that your Cl is still falling
Old   February 4, 2011, 11:10
John
Please see my problematic issue with my mesh I changed it from coarse to medium and had errors:-
- The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology.
- A mesh could not be generated using the current meshing options and settings. Hint: The problem geometry areas might have been highlighted. Switching to wireframe mode may make them more visible.
What can I do to fix this issue?
Old   February 7, 2011, 02:14
-mAx-'s Avatar
Maxime Perelli
As I said, I don't have experience with Workbench
Old   February 20, 2012, 12:39
bf77iw is on a distinguished road
enter 1 0 0 for Force Projection on x-axis
enter 0 1 0 for Force Projection on y-axis
enter 0 0 1 for Force Projection on z-axis
Now choose the right force you want to observe, and enable the plot option in monitor/force
Fluent will plot the accorded Coeff while iterating.
Your solution will be full converged if the the plotted coefficient remains constant while iterating.
You also have to set the right reference values for getting the right Coefficient
Hello max
I have a problem with Ansys Fluent too. I am wondering is there any recomended link to test aerodynamic on automotive such as truck or car. My drag and lift coefficient is not the same as I found in those journals.
Is there any improtant things i should beware when doing simulation on a scaled model? Some journal stated that the Reynolds number of model and real scale must be the same, is that so?
bf77iw is offline   Reply With Quote
Old   February 21, 2012, 06:50
-mAx-'s Avatar
Maxime Perelli
for coefficients, you have to set reference parameters
http://my.fit.edu/itresources/manual...ug/node972.htm
Old   February 23, 2012, 02:24
thx for the reply. will figure it out.
Old   March 16, 2012, 12:15
sheth roh
sheth is on a distinguished road
I would like to know how can we plot Cl Vs time and Cd-time on a moving body. At each instance the vector perpendicular to surface would change in such cases.
sheth is offline   Reply With Quote
Old   October 8, 2015, 12:39
mali28 is on a distinguished road
I am working on similar problem that I need to calculate drag force, but I have a cylinder which is rotating on its own axis as well as on the central axis of a 5 times larger cylinder. So the force component is not x or z it will be some combination of x and z. Like the radius is r=sqrt(x^2+z^2). I am not sure about the resultant drag force, how to compute it.
mali28 is offline   Reply With Quote
Old   March 21, 2017, 20:53
Default fluent 3d
  #31
Barata Laode
barata is on a distinguished road
Dear all,
I am a new comer in fluent analysis,
Does anyone can provide possible explanation why I get zero Cl value in my result, I run fluent 3d rectangular cantilevered into water tunnel
thansk alot
regards
Barata
barata is offline   Reply With Quote
fluent, lift coefficient
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/fluent/65095-how-find-lift-coefficient-fluent.html
Posted By For Type Date
Drag coefficient simulation in ANSYS 12.0 Fluent - Forum - F1technical.net This thread Refback November 21, 2013 12:39
Problem with lift force coefficient summer FLUENT 0 May 7, 2008 11:35
Lift force coefficient for 2-phase flow Summer FLUENT 0 April 29, 2008 18:58
negative lift coefficient? please help! fumie FLUENT 1 October 9, 2007 04:52
Zero Coefficient of Lift Problem MH FLUENT 0 February 25, 2007 12:48
lift coefficient in vof kiran FLUENT 0 August 8, 2005 06:30
