Including radiation when temperature is expressed as a UDS in porous media
Old   May 29, 2009, 11:57
Default Including radiation when temperature is expressed as a UDS in porous media
mj sharawi
mj_no7 is on a distinguished road
Hi all ,
I am trying to model flow in porous media using non-equilibrium model (two different energy equations for the solid and gas phases). Where I used a UDS as the temperature of the solid phase.
My problem now is this: I need to add the effect of radiation emmited from the solid phase. The first thing I tried to do is implement discrete ordinates method using also UDS's, but it was a little difficult. Can anyone help me with that ? it is not necessarily to use discrete ordinates method, any suggestion is welcomed.
Thanks in advance ,
MJ
mj_no7 is offline   Reply With Quote
Old   May 31, 2009, 10:36
Rami Ben-Zvi
Rami is on a distinguished road
You seem to have a similar problem as the one described in the following thread
http://www.cfd-online.com/Forums/flu...ous-media.html
Unfortunately - there is no response by Fluent support and no user interest expressed in solving it... We are now checking with STAR support (which seems much more responsive) if this is possible with their software.
Rami is offline   Reply With Quote
Old   June 3, 2009, 13:31
mj sharawi
thanks Rami for reply.
I checked the thread you gave me, it does look a little similar. Anyway, I think we made good progress with the method I mentioned above (implementing the DO method using UDS's) and that should do it.
Thanks again for your reply.
MJ
radiation, thermal non-equilibrium, uds, user defined scalar
UDS porous media Nagendra FLUENT 12 August 17, 2022 14:30
UDS for Porous Media cp FLUENT 6 June 26, 2012 14:44
Porous media convection UDS equations cp FLUENT 1 September 19, 2003 20:53
temperature distribution in porous media Alexey Siemens 1 June 23, 2003 02:11
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
