Floating body.
Old   May 26, 2009, 22:26
Default Floating body.
paka is on a distinguished road
Hello everyone,
I want to model floating body on the surface of the water, which floats by its own buoyancy. I want to assume constant water flow, where floating body most likely would have the same speed as water flow. I want to model its travel history along the run. Please see attached picture for reference.
Could anyone please provide some tip how to define it in Fluent?
If one defines element like this in the middle of the domain it will be simply fixed element with wall boundary conditions, which will not move. I still want to have this element rigid and with wall boundary conditions, however, I want to have it float and traveling with water.
Thank you,
KRST
paka is offline   Reply With Quote
Old   February 26, 2010, 12:03
Default floating body
Elahe
ekakavand is on a distinguished road
Hi paka
i wanna to simulate a floating body in water too.
in this time that i write this post, maybe you solved your problem,
did you finished it? could you please help me about it.
do you have paper from it?
i'm thinking about moving mesh, but i don't know the tricks for mesh generation, moving mesh method ..etc.
Any help will be greatly appreciated.
the best,
elahe
ekakavand is offline   Reply With Quote
Old   June 10, 2010, 01:52
Hi there,
It was not my main topic of research, but I think the problem can be tackled with 6DOF Fluent model. Try to find the tutorial, it is on the web.
Best,
Psor
Body force at the cell face Souviktor Fluent UDF and Scheme Programming 0 March 31, 2009 09:54
HOW TO GIVE BODY HEAT GENERATION TERM NITUL KALITA FLUENT 3 December 18, 2008 12:23
cooling a solid body Ralf Schmidt FLUENT 1 April 16, 2007 11:54
Inquiry, post results on airflow over auto body Roland CFX 1 July 1, 2006 15:16
oscillating body fred FLUENT 1 April 1, 2005 14:41
