May 26, 2009, 08:28 |
Fluent 12.0
Rep Power: 17 |
Hi guys,
I am trying to use the new version of FLUENT 12.0....that is incredibly slow!! has anyone experienced the same?? Thanks Cinzia |
May 26, 2009, 11:43 |
Kestas
Rep Power: 17 |
I'm using Ansys products v12, including FLUENT 12. Speed is good.
But there are big bug: I see no 2D regions i specified using CFX mesh, when i run fluent 12 from ansys 12 workbech project! So i am using a trick: I create mesh and specify 2D region names in ANSYS v11 workbench CFX mesh, save mesh file for FLUENT and open it with Fluent v12 Do you have such problem? or are you using gambit to create mesh? |
May 27, 2009, 20:57 |
Fluent 12 Performance - Named Selections
Kambiz
Rep Power: 17 |
Cinzia:
I am using Fluent 12 (release version not beta) and it works really well. Provide more information on your computer/Fluent setup. I also using it on a Microsoft HPC cluster and am extremely satisfied with the performance. Kestas: That is not a bug. You need to use Names Selections in Workbench meshing for 2D surfaces (inlets/outlets/walls etc). Try import the mesh into a Workbench Mesh Component, add the Named Selection in there and then import it into Fluent. -Kambiz |
May 29, 2009, 13:21 |
Svetlin Filipov
Rep Power: 17 |
The speed is good but the user-interface.... BAD WORK people from ANSYS really bad work....
June 12, 2009, 07:14 |
Svetlin Filipov
Rep Power: 17 |
With trying to incorporate ANSYS interface type to FLUENT, the final product is not very good and the short definition is bad.
bad (vs. good) atrocious, abominable, awful, dreadful, painful, terrible, unspeakablecorked, corkydeplorable, distressing, lamentable, pitiful, sad, sorryfearful, frightfulhard, toughhopelesshorridicky, crappy, lousy, rotten, shitty, stinking, stinkyillincompetent, unskilledmediocrenaughtynegativepoor |
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
FLUENT versions ... | Gautam | FLUENT | 3 | November 1, 2007 11:49 |
Run Fluent in batch mode | Shengping LUO | FLUENT | 2 | October 24, 2000 06:42 |
