2D swirling flow NOT axisymmetric
Old   May 23, 2009, 11:43
Question 2D swirling flow NOT axisymmetric
Giuki Cael
Giuki is on a distinguished road
Hey all,
I'm simulation reactive flow through a combustion chamber. Due to the geometry of the chamber I cannot specify a symmetry plane. In that way I cannot use the axisymmetric swirl solver in Fluent. As the air and fuel is not mixing and not behaving as they would with a physical swirler, I am wondering if there are 'trics' to be able to simulate swirl in a 2D problem. These could as well be geometrical trics in order to redirect the flow. I've been trying and searhing but haven't found a solution for my problem.
If you desire more information, feel free to ask!
Thanks in advance!!!
Giuki
Giuki is offline   Reply With Quote
Old   May 29, 2009, 02:09
Farhan
sfaquadri is on a distinguished road
Send a message via MSN to sfaquadri Send a message via Yahoo to sfaquadri
is your axis horizontal??
Fluent will consider axi symmetric models only if u have the symmetric axis as horizontal..
do i answer you ??
Farhan
sfaquadri is offline   Reply With Quote
Old   May 29, 2009, 04:22
Giuki Cael
Dear sfaqaudri,
Thank you for your reply! Well, I'm aware of that constraint, but it is in my problem definition that my complete model is way above the axis? Which makes that no axis lies in my domain and for which I cannot use any axisymmetrical solver of Fluent.
I wanted to know if there are some 'tricks' to model swirl in 2D without using the "2D axisymmetric swirl" model.
Regards!
Old   May 30, 2009, 01:30
Farhan
well.. am not so well versed with fluent, but i would go with velocity components (tangential component) and get my work done..
all the best !
combustion, swirl, two-dimensions
Level set equation in axisymmetric 2-D flow jinwon park Main CFD Forum 0 February 26, 2008 17:26
Swirling FLow Parag Gadgil Main CFD Forum 0 February 13, 2008 06:10
axisymmetric main flow + injection Stephan FLUENT 1 January 19, 2006 12:43
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
Axisymmetric Flow S. Kumar Main CFD Forum 0 November 10, 2001 11:15
