beginner's questions about fluent paralle processing
Old   May 17, 2009, 19:22
Default beginner's questions about fluent paralle processing
Renold is on a distinguished road
My computer has a core i7 920 (quad core) cpu, 12gb memory, and vista 64bit. Now I am using fluent 6.3 64bit to perform paralle computing. The grid info is as below:
Level Cells Faces Nodes Partitions
0 57756 121860 62462 1
The computation time for serial computing is about 9 h. The wall-clock time for 2-processer paralle computing is about 5.5 h. If I use more than 2 processors, the wall-clock time does not change. I am wondering if it is because the nodes are two few.
Plus, I noticed that when fluent was running the page file usage increased. Can I increase the usage of memory and reduce that of page files? I think that would make the computation faster.
Another question is that it is better to turn on SMT or not?
Thanks in advance.
Renold is offline   Reply With Quote
Old   May 18, 2009, 01:53
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
Your mesh is too small.
Try with a mesh with 1 million cells you will see the difference
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
CFD beginner:- Help needed, general questions on Free jets? (Fluent 5.2.3) Wong, R.Y.T. Main CFD Forum 5 October 22, 2010 01:51
solving ocean wave with Fluent or CFX? gholamghar Main CFD Forum 1 March 21, 2009 13:49
FLUENT + QUESTIONS kospan Main CFD Forum 4 July 30, 2008 17:30
Post processing in fluent carno FLUENT 0 July 19, 2007 01:59
Parallel Processing by FLUENT? M Kermani Main CFD Forum 2 February 21, 2001 11:01
