May 15, 2009, 06:18 |
vapor transport through membrane pores
Rubina Bahar
I have to simulate the heat and mass transfer when vapor passes through membrane pores.it is a phenomena under membrane distillation process. This vapor will be generated as a result of evaporation from hot water.and this vapor will travel through the membrane on the other side where there is a cold surface to produe condensate. as a newbie in FLUENT can I get some ideas on where to start? like how to link the evaporation caused by difference in partial pressure between the hot and the cold side? |
membrane distillation, vapor partial pressure |
porous filtration membrane area in model | catherina | CFX | 3 | October 27, 2011 07:05 |
Membrane distillation system .. URGENT | ashish | FLUENT | 0 | June 9, 2008 20:03 |
UDF for vibrating membrane | Sherif | FLUENT | 0 | November 9, 2004 11:17 |
moisture transfer through membrane | m. Nasif | FLUENT | 0 | October 23, 2003 04:41 |
mass transfer from fluids to membrane | Peter | FLUENT | 0 | August 2, 2002 15:27 |
