Issues with dynamic meshing
Old   May 8, 2009, 03:22
Default Issues with dynamic meshing
Sridhar S
sridhu88 is on a distinguished road
I am working on a 2D problem where you have a beam like structure inside a square enclosure. The beam is fixed at one end and oscillates up and down(I used rigid body motion UDF to do this). But the dynamic meshing isn't working properly when I use rectangular elements near the beam. It seems to work reasonably well when I have triangular elements near the beam. But the Gambit boundary layer meshing option allows only rectangular elements near the boundary. So how do I make my model work for rectangular elements also?
Also I am confused about which dynamic mesh algorithm(Smoothing, Layering, Remeshing) I should be using..I would be happy if somebody can explain about this also.
Thanks,
Sridhar
sridhu88 is offline   Reply With Quote
Old   June 11, 2009, 17:46
mrestrepo30 is on a distinguished road
what is the configuration you have for the dynamic mesh parameters? are you using layering accompanied by smoothing or remeshing?
If you are only using layering, try typing
define/models/dynamic-mesh-controls <enter>
define/models/dynamic-mesh-controls/ sp <enter>
define/models/dynamic-mesh-controls/sp/soas <enter>
[yes]
this will "activate" the layering option for the structured mesh.
mrestrepo30 is offline   Reply With Quote
negative cell volume during dynamic meshing Tamjid FLUENT 1 September 5, 2011 03:33
Dynamic meshing Manoj Kumar FLUENT 3 June 27, 2010 20:26
help for dynamic meshing for incylinder combustion Ramesh K FLUENT 0 June 19, 2006 07:29
Dynamic Meshing Problems Shuto FLUENT 3 January 19, 2005 21:09
dynamic meshing option arehman Main CFD Forum 4 June 27, 2004 03:55
