Mixture multiphase model
Old   May 4, 2009, 01:49
Default Mixture multiphase model
sourplum
sourplum is on a distinguished road
Send a message via Yahoo to sourplum Send a message via Skype™ to sourplum
Dear all,
Before i go any further, i think better i explain a little bit about my projects. I'm doing simulation on mist elimination system where a gas stream with a fraction of mist ( water fraction = 0.004, droplet's diameter = 0.1 mm ) is allowed to pass through torturous channels with a velocity of 4-7m/s. I chose to use mixture multhiphase model to deal with my two phases problem.
I've got the following result as I summarize the mass- flow through the inlet and outlet of the passage.
For the mixture:
zone 5 (inlet): 0.12247331
zone 4 (outlet): -0.12246391
net mass-flow: 9.3979068e-06
For the primary-phase which is air
zone 5 (inlet): 0.12246401
net mass-flow: 1.0460325e-07
For the secondary phase which is water
zone 5 (inlet): 0
zone 4 (outlet): 0
net mass-flow: 0
I'm wondering why the mass-flow for water is zero. It seems like fluent already pre-defined the mixture's phase fraction as zero for the water. Would anyone advise me on this matter?
Thanks and regards,
sourplum
sourplum is offline   Reply With Quote
Old   May 19, 2009, 08:27
John Gallagher
johngsl is on a distinguished road
Im pretty new to Fluent but I can simply see why the net-mass is 0. As with the mixture and primary phase it is zone 5 minus zone 4.
I think what you need to do is analyse internally in the model with the surface tools.
Hope im not stating the obvious,
John G
johngsl is offline   Reply With Quote
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 19:13
Turbolence model for multiphase flows lu CFX 1 February 7, 2007 17:40
multiphase model Sumeet FLUENT 2 August 31, 2005 09:26
Converge problem of Mixture Model Jen FLUENT 8 August 17, 2005 19:23
Multiphase Mixture Model fluent5.4 Julia Kullmann FLUENT 0 March 9, 2001 06:13
