May 1, 2009, 12:12 |
Creating bitmap images from fluent
Luke
Hi there. very trivial question. ive created a set of heat transfer models on spinning disk brake rotors for my dissertation project. i need to save the contours of total temperature in bitmap or another image file type. i know you can do this and get rid of the black background too. can anyone please enlighten me? cheers luke |
May 1, 2009, 13:07 |
Ralf Schmidt
Rep Power: 17 |
Hi!
use ->file -> hardcopy Best wishes Ralf
CFD - nothing but Colourful Fluid Dynamics |
May 1, 2009, 23:55 |
Hi friends..
What I usually do is displaying the graphic first (e.g. grid, contours, vectors etc) and then zoom to my zone of interest. At this time, u'll absolutely see a tab of the window u're displaying at the taskbar. right click at the tab and choose copy to clipboard. If u get bnw image, try to change the setting by right click at the tab and go to "page setup" and change the radio button from grayscale to color. Good luck in your project p/s: I haven't try your method ralf. Thanks for sharing =) Best regards, sourplum |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Integration of a Custom C++ Model into FLUENT | Syed Haider | FLUENT | 2 | March 7, 2018 00:37 |
Comparing Fluent Time dependent result with Patran | venigall | FLUENT | 0 | January 13, 2007 20:30 |
FLUENT to ANSYS Temperature Mapping Procedure | schreiberc1 | FLUENT | 0 | June 29, 2006 14:50 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 04:27 |
