Mass flow rate in a 1/4 pipe (periodic boundary) |
April 30, 2009, 15:15 |
Rep Power: 17 |
If I draw only 1/4 of the real inlet of the pipe (I use periodic condition and I study only a "V" domain), I have to set 1/4 of the mass flow rate?
May 1, 2009, 01:16 |
Maxime Perelli
Rep Power: 41 |
yes.
But you can use also the symmetry BC
In memory of my friend Hervé: CFD engineer & freerider |
May 1, 2009, 15:41 |
Rep Power: 17 |
You are right.
I've not specified that I have 4 radial injection flows equally spaced, so I used a periodic boundary condition (and not symmetry) I set periodic boundary conditions with 0 pressure gradient |
boundary condition, mass flow rate, periodic |
Mass flow rate and periodic boundary | allamarein | FLUENT | 2 | April 21, 2009 06:21 |
Reg Mass flow rate | jksanil | CFX | 1 | January 6, 2009 04:08 |
How can apply mass flow rate boundary condition? | Sima | Phoenics | 1 | December 1, 2007 19:55 |
negative global mass flow rate | Gimli | FLUENT | 0 | April 21, 2006 08:17 |
Mass flow rate through a valve | Martin Sigrist | FLUENT | 1 | December 8, 1999 16:00 |
