Fluent_Error:pressure-far-field boundary conditions can only be used with ideal gases
Old   April 23, 2009, 04:50
Unhappy Fluent_Error:pressure-far-field boundary conditions can only be used with ideal gases
unknown
unknown is on a distinguished road
It is the study of NACA0012.
Data:
Polytropic Ideal Gas
Gamma=1.4
Poo=85419 Pa
Too=260 K
Moo=0.75
alpha=0.4
Boundary conditions:
- Naca0012: WALL
- Farfield around Naca0012 (a circle enclosing naca): PRESSURE-FAR-FIELD
Gauge pressure (pascal): 85419 (Pa)
Mach number: 0.75
X-Component of flow direction: 0.997564
Y-Component of flow direction: 0.069756
....When I iterate the following error appears:
Error: pressure-far-field boundary conditions can only be used with ideal gases.
Error Object: ()
Does anyone know the reason?.
Thanks for your time!.
unknown is offline   Reply With Quote
Old   April 23, 2009, 11:00
doki is on a distinguished road
that means you should set the air density type as "Ideal Gas" in the material properties panel before setting the BC and iterating.
one other thing, how could you set the Mach number for the incompressible fluid?
doki is offline   Reply With Quote
Old   November 24, 2011, 13:43
mohanad hussien
mohanad07 is on a distinguished road
I have problem when I use pressure far field there is divergence occurs quickly on residual solution panel, what Ido?
mohanad07 is offline   Reply With Quote
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 13:58
Boundary Conditions for Incompressible Flow Bob FLUENT 0 April 7, 2006 22:28
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Far Field Boundary Conditions Xavi Main CFD Forum 8 December 17, 1998 09:11
