Problem in running fluent 6.3 (64 bit) on ubuntu 8.1 (64 bit) |
April 20, 2009, 04:01 |
Reza Khane Mir5
I have problem in installing fluent 6.3 on ubuntu 8.1
I have installed the fluent software and then installed following packages: sudo apt-get install libstdc++5 sudo aptitude install libmotif3 sudo aptitude install libxaw7 /Martin So i run the fluent in 2d or 3d version But i have the following error : /Fluent.Inc/license/lnamd64/fluentlm-helper91: no such file No error handler available .... Anybody Can Help? |
April 22, 2009, 10:49 |
hardware
nazareno mancinelli
Rep Power: 17 |
hello Mir5.
can you tell me what hardware are you using? why did you install libīs? do you have only this message error? you may have more information launching fluent in a console window.- regards chule |
April 28, 2009, 14:47 |
Same Problem
Michael
I am having the same errors. I am running mine in a VMware 5 workstation VM. I was actually looking to see if this may be the problem. As far as the actual hardware it is runing on an HP workstation, Intel c2d 3.16GHz, 8G ram, nvidia geforce card. None of that should matter since its in a VM.
I too installed all the extra libs because of responses in other threads. Right below this error I also get: Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: () Error: eval: unassigned variable Error Object: rp-3d? After I close the Fluent program I get this on the terminal window: XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0.0" after 4745 requests (4709 known processed) with 0 events remaining. along with a stack backtrace generated for process id 448 on signal 11 and then a bunch of stuff (thats a technical term). |
April 29, 2009, 11:32 |
Mine is solved!
Michael
Mine is solved! I installed the 32 bit lib32stdc++6 and it worked. I also installed the lib32gcc1 but I don't think that was the issue.
Problem running fluent with InfiniBand | blackpuma | FLUENT | 10 | August 28, 2011 02:16 |
window xp 64 bit (64bit) for fluent 6.3.26 (64bit) | Far | FLUENT | 1 | April 7, 2009 21:20 |
Licensing problem with Fluent v5.5 | moiami | FLUENT | 3 | April 17, 2002 04:50 |
Can FLUENT solve this type of problem? | Whitaker | FLUENT | 3 | October 23, 2000 04:01 |
FLUENT 5.2.3 running on PIII 733 | Burley Wang | FLUENT | 7 | April 19, 2000 07:03 |
