How to plot pressure drop with Periodic BC?
Old   April 20, 2009, 02:23
Smile How to plot pressure drop with Periodic BC?
realworld
bigfans is on a distinguished road
Anybody can help me to plot the contour of pressure drop of a system with periodic boundary conditions?
Although I can read the pressure drop gradient from Monitor window, the contour of pressure drop I plotted is totally periodic, which is only the periodic part of total pressure drop as discribed by Fluent Mannual. So how to plot the real pressure drop field in Fluent?
Thanks!
bigfans is offline   Reply With Quote
Old   April 20, 2009, 04:35
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
If you mean, you want to display all the domain, then go to display/view and there is a panel specific for periodic repeats on the right
-mAx- is offline   Reply With Quote
Old   April 20, 2009, 11:33
realworld
I just want to visualize the real pressure field of the computational domain. Since there must be pressure drop from inlet and outlet, the real pressure field should not be repeated from inlet and outlet, as shown in Fluent.
By the way, I monitored the pressure gradient (pa/m) through the Monitor/statistics as suggested by Fluent mannual, but why this value is different from the Monitor/surface/area-weighted average value (pa) divided by the length between periodic inlet and outlet (m)? Since I set periodic BC for inlet and outlet, there is only entity to select in area-weighted average, so is this average value the pressure drop between inlet and outlet?
Appreciate all suggestions!
Old   April 20, 2009, 11:59
Buddy
zjbwow is on a distinguished road
hi max
glad to see you again
I've met similar problems in my work.
I want to define a point so that I can trace its pressure change but failed cause the command to define a point can only work in 2D model.
any suggestions for the 3D model ?
thx
zjbwow is offline   Reply With Quote
Old   April 20, 2009, 12:17
-mAx-'s Avatar
Maxime Perelli
*bigfans: post a picture of your issue
*zjbwow: post a new thread and explain your issue
Old   April 21, 2009, 01:13
Buddy
gooooooooooooot it.
Old   August 7, 2009, 08:48
spk
spk is on a distinguished road
Hi guys,
I try the second tutorial in Fluent (Modeling Periodic FLow and Heat Transfer). Can i plot the real contour of pressure field?
spk is offline   Reply With Quote
Old   November 8, 2016, 12:28
Shamoon Jamshed
Shamoon Jamshed is on a distinguished road
Send a message via Skype™ to Shamoon Jamshed
Although this post seems very old, hopefully I get some answer, I am experiencing the same issue. By the way bigfans! there is no inlet and outlet because you have defined periodic domains over there. I am also getting some absurd value, with Mega pascal drop and its increasing from -9e6 to -9e5 and so on, I do not know where to stop?
Shamoon Jamshed is offline   Reply With Quote
Pressure drop? Munni FLUENT 4 March 25, 2010 15:21
Pressure drop of valve with valve opening of 30% elogesh Main CFD Forum 2 January 5, 2007 13:30
cyclone pressure drop - reg Subramanian.J FLUENT 2 December 22, 2006 06:34
Pressure drop in periodic turbluent pipe flow lou FLUENT 0 September 21, 2005 01:58
specified pressure drop subhra Main CFD Forum 0 May 29, 2005 13:43
