How to read IC Engine cylinder pressure
Old   April 16, 2009, 12:22
Question How to read IC Engine cylinder pressure
sreenivasulu
mslu544 is on a distinguished road
Dear Sir,
I am trying to read cylinder pressure of an IC Engine, I could model the combustion chamber and run the case in FLUENT, but i could not read cylinder pressure. Some body please help me which option i should use to read this.
m. sreenivasulu
mslu544 is offline   Reply With Quote
Old   April 18, 2009, 01:35
doki is on a distinguished road
you can use volume integrals (in report menu) to integrate the pressure inside the cylinder and get the values.
also if you are willing to get the calculated value for different crank angles, you can set the same settings in the define/animation before running the case.
doki is offline   Reply With Quote
Old   April 19, 2009, 08:19
Default ICE simulation from the FLUENT tutorial
Yashodeep
yash is on a distinguished road
I am new to FLUENT and i m trying to run the ICE cold flow simulation tutorial given by FLUENT. I followed all the steps given but still I am getting error after I apply the initial conditions:
WARNING: Unassigned interface zone detected for interface 21
WARNING: Unassigned interface zone detected for interface 26
Error: Init_Flow: unassigned interface_zones
Error Object: ()
What could be the possible problem is it with the mesh or case set up?
I assigned all the zone as per the tutorial.
Please help me with this.
Thanks,
Yashodeep
yash is offline   Reply With Quote
Old   May 19, 2009, 10:19
Smile
sreenivasulu
[QUOTE=yash;213425]Hi,
Error Object: ()
I have seen ur message today
initialization problem- it might be at interface_zones
if u can send the soft copy (pdf) i can suggest u.
sreenivasulu
Old   May 19, 2009, 17:49
Yashodeep
thanx i was able to fix it.. there was problem with the boundary conditions
How to read pressure from a designated path jennyrui2008 OpenFOAM Running, Solving & CFD 0 December 4, 2008 05:48
Input flowrate and outlet pressure in a cylinder philippe FLUENT 0 June 23, 2008 05:48
Pressure Condition sidd Siemens 0 April 2, 2007 10:31
base pressure for circular cylinder fpz Main CFD Forum 7 June 20, 2005 22:30
pressure gradient term in low speed flow Atit Koonsrisuk Main CFD Forum 2 January 10, 2002 11:52
