March 27, 2009, 18:30 |
Polyhedra and sliding mesh?
Ewan
Rep Power: 17 |
I am doing some simulation in mixing tank using FLUENT. Because the impeller is a close clearance impeller, it has very small gap between the impeller and the tank wall. The impeller blades are quite thin too. All these create a lot of trouble for grid generation. Usually, there would be a couple of grids have a skewness of higher than 0.9 (less than 0.95, though), and a dozen of grids higher than 0.85. Using smaller mesh size doesn't really help reducing the skewness. If I run sliding mesh method on this mesh, usually there would be some convergence problem sooner or later, probably due to the left-handed faces created during the movement of the rotating zone. I tried converting the whole domain to polyhedra mesh. It would run fine and much faster because of much less grids. However, I found that the velocity profile is not physically reasonable on the interface between the rotating zone and the stationary zone. So I was wandering whether I could use polyhedra with sliding mesh, is there any compatability problem? It is also welcome if anyone know how to reduce the skewness effectively without using too much grids. I am already getting about 2 million grids at the moment.
P.S.: I checked the FLUENT user's guide on the polyhedra limitations. It does not say anything on sliding mesh or MRF. FLUENT model compatibility chart didn't say anything about polyhedra mesh either. |
March 28, 2009, 19:10 |
Rep Power: 17 |
Currently, polyhedral mesh cannot be used in any moving or sliding mesh model
March 29, 2009, 12:31 |
Rep Power: 17 |
I agree with panda, Fluent user guide is clear at this point: for now, no capability for sliding mesh with polyhedra mesh ...
Greetings, Freeman |
July 3, 2009, 05:36 |
Rep Power: 17 |
Could either of you point me to where in the user guide it says that the polyhedral approach can't be used with sliding meshes? I can only find reference to deforming/dynamic meshes, not sliding meshes.
February 21, 2012, 07:00 |
sliding mesh , plz help
Rep Power: 14 |
hello
i am not able to apply sliding mesh in train moving in tunnel. can any body help me. my email sheikhnasir39@gmail.com thanks |
December 1, 2018, 20:07 |
jose antonio guzman santana
Rep Power: 9 |
u need to set the interfaces as non sharing faces, then it will let you create a non conformal interface, thats the thing with sliding mesh
