Fluent Output Data Question
Old   March 27, 2009, 18:00
Default Fluent Output Data Question
Nicole
fossu15a is on a distinguished road
I have a grid which I have imported into Fluent. I want to export three "tables" of data from my mesh, velocity magnitude at a specified point, instantaneous centerline velocity (along a line of symmetry) and velocity profile of axial velocity at a specified point. Eventually I need to input this data into Matlab. I've tried exporting data in a ASCII format, but it is only returning the data point I've set. How can I extract this information?
Thank you in advance
fossu15a is offline   Reply With Quote
Old   March 28, 2009, 07:23
mbernard is on a distinguished road
hello
I'm not sure the answer I'll give you will be efficient , but, by using XY-plot, you can export some datas into text or xls files. For example, I use it to export temperatures along walls.
You just have to tick the Box " write to file" in the XY plot panel, and name the file. Don't forget to tick the " order points" , to keep the values ordered by x or y position.
Hope it will help you
regards
mbernard is offline   Reply With Quote
Old   March 30, 2009, 02:58
paka is on a distinguished road
What I understood is, you are able to dump the data into ASCII file but then you need to structure them into specific way, is it right?
paka is offline   Reply With Quote
Old   March 30, 2009, 20:29
Nicole
Yes I'm trying to output the data, but that format is only giving me one line of given information. I'm now trying to use a surface monitor at a point, but I can't seem to calculated the axial velocity at a given point.
output
[OpenFOAM] Output data file on the line of the example zhoubinwx ParaView 0 February 13, 2008 05:59
data output from batch fluent run Wang FLUENT 4 March 11, 2005 12:01
How to get u,v,w velocities from Fluent Data file Kumar FLUENT 2 November 10, 2004 11:36
reading data into fluent co2 FLUENT 0 December 28, 2003 02:31
Question on openning mesh from Fluent Derek Jing FLUENT 5 April 22, 2002 16:55
