Degassing boundary condition in Fluent?
Old   March 24, 2009, 09:18
Default Degassing boundary condition in Fluent?
JP
srjp is on a distinguished road
Hi, I am running a simulation of a bubble column with a free liquid surface on top, in Fluent.
I need to set a boundary condition for the top surface, where the air bubbles can escape, but the liquid cannot. In Fluent, currently all I can do is to set this surface as a pressure outlet with backflow volume fraction of air as zero. But this does not prevent the liquid from leaving the boundary.
Is it possible to set the boundary condition so that air can leave the boundary but liquid cannot? (Similar to the degassing B.C. in CFX)
I am running the mixture model, with 2D geometry, bubbles injected from bottom.
srjp is offline   Reply With Quote
Old   August 17, 2011, 23:26
Calvin
Tongji Environment is on a distinguished road
The same question to you, Pray for reply
Tongji Environment is offline   Reply With Quote
Old   August 18, 2011, 09:46
JP
Looks like there was no straight forward method to do this. I had taken a taller air section in the top, so that liquid does not leave the boundary. I had also patched the top region with air.
Old   November 23, 2015, 13:56
Default degassing boundary condition
azna
azna is on a distinguished road
I'm working on a bubble column. I was wondering that how can I modify settings in the degassing boundary condition ? close to the water surface, it under predicts velocity for both air and water. Is there any way that I can fix this problem near the water surface ? the flow pattern with degassing boundary is correct however, velocities near the water surface is very low comparing with experimental values.
Thanks a lot
azna is offline   Reply With Quote
Old   June 12, 2018, 10:53
Default Pressure at degassing boundary
Lukas
Sijnhaven is on a distinguished road
Dear all,
I am modelling a liquid vessel with side injection of gas. For the inlet I am using a pressure-inlet.
The liquid may not leave the domain, only the gas is allowed to leave the domain.
I believe the degassing is the appropriate choice, because it alows te gas phase to leave the domain, but not the liquid phase. However, this boundary conditions does not allow to specify a pressure (which should be atmosferic pressure) at the outlet.
This will also influence the pressure inside the liquid domain. The hydrostatic pressure will not be Patm + rho*g*h in this case?
How to handle this case?
Sijnhaven is offline   Reply With Quote
Old   May 12, 2023, 05:32
Parthasarathy yuvaraj
yuvarajp is on a distinguished road
hi, u raised the question 13years back, did you find the solution. ur suggestion would be appreciated
yuvarajp is offline   Reply With Quote
UDS problem with wall boundary condition Alex F. FLUENT 15 September 21, 2015 10:28
inlet velocity boundary condition murali CFX 5 August 3, 2012 09:56
Degassing boundary condition Ayman Dohdoh FLUENT 0 October 28, 2007 05:41
Spectral Method Boundary condition Deepak Main CFD Forum 1 February 25, 2004 10:48
FLUENT Boundary condition problem Khalid Main CFD Forum 1 December 2, 1998 20:54
