help for opening gambit file n Fluent.....
Old   March 22, 2009, 13:07
Default help for opening gambit file n Fluent.....
rizwan
rizwan is on a distinguished road
hello to all
hope u all fine... i wana open the gambit file in fluent but it gives me the error "null pointer domain error" . i actually completed the second tutorial of the gambit as it is described in the gambit tutorial... but when i tried to open that n fluent it give the above error... plz help n in this regard....
rizwan is offline   Reply With Quote
Old   March 22, 2009, 23:41
paka is on a distinguished road
Are you sure you are using Gambit?
Such problem appears when surfaces normal vectors do not conform with main model axes for triangular grids or in case of rectangular meshes only x and y axes.
I do not use Gambit anymore, I think it is not a very good tool. However, it is still possible to have your job done
If you are Gambit fan, forgive me, maybe newer versions are better than what it used to be in the past, dunno.
Usually "null pointer domain error" appears when you use external (it means not Fluent provided meshers) meshing software. For example your lines or surfaces are defined in wrong directions.
If you need more explanation let me know, I will try to elaborate more. Right now check mesh axes alignment with Fluent main axes.
Best,
Krst
paka is offline   Reply With Quote
Gambit and Fluent Help Vincent Ryan FLUENT 2 January 11, 2009 08:34
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 05:59
No Fluent menu letters, no libXp.so.6 for Gambit Gijsbert Wierink FLUENT 1 September 4, 2008 19:10
Retrieving files in GAMBIT & FLUENT Vidya Raja FLUENT 0 November 5, 2005 21:26
PHI file structure Eugene Phoenics 9 November 2, 2001 23:00
