Second Order Upwind: Residuals
Old   March 27, 2009, 10:58
zhao peng
zhaopeng is on a distinguished road
This may seem a bit strange,i advise you slove the case you upload again.
zhaopeng is offline   Reply With Quote
Old   March 27, 2009, 12:03
Enry Lorna Neil
enricokr is on a distinguished road
Yes i'm using double precision...
Your results at the number of iterations you indicate aren't the same of mine... I don't know why!
Changing URF of pression from 0.3 to 0.1 i have the result i want, but is it a correct method?
And what means to decrease URF?
Excuse for my bad knowledge...
enricokr is offline   Reply With Quote
Old   March 27, 2009, 13:35
paka is on a distinguished road
Maybe it is completely wrong approach, but what happens if you try to use transient solver?
paka is offline   Reply With Quote
Old   March 27, 2009, 14:29
Enry Lorna Neil
Why i have to use a transient solver if the problem is steady?
Old   March 27, 2009, 15:49
I'm didn't say you have to, I said that maybe something unexpected happens if it breaks so early. I don't know
Old   March 29, 2009, 16:25
Enry Lorna Neil
I repost the former question:
Does anyone know it?
Old   March 29, 2009, 19:22
MrFluent
mr_fluent is on a distinguished road
i was about to ask you to reduce mom urf little bit. Or reducing pressure urf would help but might not be the case always.
urf of pressure results in slower update of pressure.
pressure_new = pressure_old + urf * change in pressure.
anyway the main reason of your problem is your grid. it is not refined enough to handle fast change that is coming in flow direction. If this situation happens the gradient of u,v,w varries very fast. And often breaking local maxima minima. When you use second order scheme there is a contribution of this term in momentum equation. If your gradients are false this term might be shooting up and down. By reducing pressure unerrelaxation the change due to pressure change is restricted (which is main change per iteration) and behaviour of second order contribution is controled better.
for steady state using low urf is no cheating. Its just a way to get converged solution.
mr_fluent is offline   Reply With Quote
Old   January 2, 2018, 13:30
Question
  #28
Achilleas is on a distinguished road
A few years later, which is the solution to this problem? I encounter the same difficulties and I did all the above things proposed..
Achilleas is offline   Reply With Quote
Old   January 2, 2018, 18:41
DEd
Daniel Edebro
DEd is on a distinguished road
Achillieas, I don't think it is an unusual experience to get crappier convergence when switch to a less robust discretisation scheme but I don't think it is something special with a pipe expansion (as the testimonies above afirm) . Therefore I would advise you to do as in every case - describe as much as possible about your case, display the mesh and ask for help.
DEd is offline   Reply With Quote
weno upwind 5th order 1 d code Chi Main CFD Forum 1 March 11, 2007 23:44
First order upwind leung FLUENT 2 June 13, 2004 09:09
second order upwind muslum arici Main CFD Forum 6 July 28, 2003 10:25
First Order Upwind Giovanni Ieria FLUENT 3 November 30, 1999 19:43
second order FD upwind scheme Heinz Wilkening Main CFD Forum 2 November 3, 1998 15:33
