[Urgent] Need help for defining boundary conditions
Old   March 18, 2009, 23:53
Default [Urgent] Need help for defining boundary conditions
tang jingwei
Jingwei is on a distinguished road
Hi all,
I'm modeling a channel flow with a winglet using Gambit, as proposed in the attached figure:
http://img27.imageshack.us/my.php?image=helpj.jpg
The boundaries that i'm currently using are:
1. Inlet: Velocity inlet
2. Outlet: Pressure outlet
3: Side walls: Periodic
4: Top wall: Symmetry
5: Bottom wall: Wall
6. Winglet: Wall
When i open the mesh file using the above-mentioned boundary conditions in FLUENT, there is a error message that says that it can't read the winglet boundary type as stated below:
materials,
interface,
domains,
zones,
default-interior
pressure_outlet
velocity_inlet
bottomwall
upperwall
Skipping zone wall (not referenced by grid).
side_walls
Skipping thread 3 of domain walls_shadow (not referenced by grid).
fluid
shell conduction zones,
Done.
Why is that so?
Also, I have a few other questions in mind:
1. As in the attached figure, the boundary at the side wall is defined as free slip. Is periodic boundary that correct boundary type to use?
2. I do not understand why the author of this paper on one hand states that the top wall is defined as a no-slip wall, in the other he states that the velocity is parabolic (i.e., Velocity_max at the top wall and Velocity=zero at the bottom wall)
Jingwei is offline   Reply With Quote
Old   March 19, 2009, 00:17
tang jingwei
add:
I have checked the mesh in Gambit, it seems to be alright:
http://img14.imageshack.us/my.php?image=help2e.jpg
Old   March 19, 2009, 22:01
tang jingwei
any help pertaining to any part of the above question is welcomed!
P/S: With regards to the problem I had in the fluent as posted in #1, I think it is b/cos I run 3ddp in fluent, thus it is unable to recognise the 2D triangular structure inside.
Defining "Neutral" boundary conditions? (force=0) MW FLUENT 5 October 5, 2009 05:55
Defining Boundary Conditions in GAMBIT Tim R FLUENT 3 April 14, 2008 05:30
Batch Mode : re-defining boundary conditions MaxiFLOW CFX 6 March 29, 2007 09:41
Defining Boundary conditions in gambit anthro FLUENT 2 February 14, 2007 10:17
[Commercial meshers] Defining boundary conditions on interior faces melanie OpenFOAM Meshing & Mesh Conversion 9 August 10, 2006 10:52
