March 18, 2009, 02:04 |
Flow Between Two Parallel Plate
Mustafa Ayad
Rep Power: 17 |
Hi
I want to simulate the Flow Between Two Parallel Plate in fluent one of plate is moving how can i do that. Regards. |
March 20, 2009, 04:37 |
Rep Power: 18 |
Create model with two plates, then apply to one of the models UDF function describing its motion.
March 20, 2009, 08:06 |
Mustafa Ayad
Rep Power: 17 |
Hi friend
Thanks for your replay, I want to tell you that my two plates on is horizontal and the other is incline by an angle (Alfa) how can I do the udf for for the incline plate I can do for horizontal plate . Regards. Mustafa |
March 20, 2009, 14:18 |
Rep Power: 18 |
Calculate its motion in its coordinates. Then apply this function to UDF. I would advise you to go through whole UDF Fluent Documentation and to get over UDF tutorials.
As far as I remember, in UDF I guess you cannot define really displacement, the only thing (I might be mistaken, this is only what I think I remember) is to define the velocity or acceleration of one of the boundaries. For example, I would define velocity function which corresponds to your boundary motion. Then monitor (Surface->Monitors) BC motion, by dumping displacements (Grid tab in X and Y) in x and y direction into two separate files. This way from your previous calculation (I would do first a stand alone Excel, C, Python, or whatever else) verify your results comparing output from Fluent to your routine. Hope this helps, Krst |
March 21, 2009, 09:25 |
moving walls
Rep Power: 17 |
Hello. I think there's an eaisier and faster way to do that stuff. I think you can aplly a velocity to your walls in the Boudary conditions paneL. you can fin d a part called " moiving wall" where you can define the velocity of your boundary.
Let us know about the solution you choose Regards |
March 22, 2009, 17:13 |
Rep Power: 18 |
Yes, actually that is true. Forgive me, sometimes too much sophisticated work stop making you think simple way
You can definitely apply velocity to your BC. Best, Krst |
March 23, 2009, 05:51 |
Rep Power: 17 |
hi
Don't worry about your answer, which is more accurate than mine. |
Flow between two parallel plate | Mustafa Ayad | FLUENT | 1 | February 23, 2009 08:08 |
Flow in a parallel plate | Andre | FLUENT | 0 | November 24, 2008 15:37 |
flow thru parallel plate with solid heat generater | cindy | FLUENT | 1 | October 10, 2005 23:54 |
Parallel Plate Rheometer vs Cone & Plate | beginner | Main CFD Forum | 0 | March 19, 2003 12:49 |
Nondimensionlization on Parallel-plate | Juhee Lee | Main CFD Forum | 1 | October 25, 2000 14:50 |
