March 14, 2009, 16:27 |
water jet simulation
How to simulate the following problem? water at higher velocity impinges through the slot nozzle on the flat plate. it it single phase or two phase problem? since water impinges through the air domain.
Please anyone can suggest the simulation methodology. |
April 28, 2009, 16:30 |
Ralf Schmidt
Rep Power: 17 |
Hi!
i am pretty sure, that is a two phase problem. The air will interact with the surface of the water jet, there might even be entrainment. But unfortunately, i don't know so much about two phase simulations....
CFD - nothing but Colourful Fluid Dynamics |
May 1, 2009, 10:59 |
Hossam S. Aly
Rep Power: 17 |
Hi, it is indeed a two phase simulation. the VOF model may give you very good visualization of the jet since it is the only model that tracks the interphase between the two phases. it is also the simplest multiphase model in Fluent in terms of computational expenses.
July 14, 2009, 16:21 |
hydraulic jump
morteza
Rep Power: 17 |
my problem is when water jet strikes the flat plane it does not flow on the plate so i cant calculate the jump !!
simulation with 2 fluids: air and water | Rogerio Fernandes Brito | CFX | 4 | March 20, 2008 18:07 |
Water wave simulation | anil | FLUENT | 2 | August 25, 2005 08:49 |
References on Water-Air CFD Simulation | AAM | Main CFD Forum | 0 | September 15, 2004 17:14 |
Air and water simulation | Mavinakere | Siemens | 1 | February 27, 2002 22:35 |
CFD-SIMULATION of WATER-SKI | frank | Main CFD Forum | 1 | February 19, 2000 15:35 |
