Heat flux BC at some walls is function of T
Old   March 12, 2009, 20:04
Default Heat flux BC at some walls is function of T
shannag
Dear friends, I would like to apply a heat flux BC at some walls which is function of Temperature. Could you help me to write UDF for this case, example Heat flux= aT^2 where a is constant and T is temperature. many thanks shannag
Old   March 13, 2009, 06:13
Default Re: Heat flux BC at some walls is function of T
A Kourm
If you have a look at the FLUENT UDF User's manual (if you dont have one just google it and it will show up somehwere), there is an example there that sets a velocity profile BC (pg. 3-4 on the 6.1 version), you effectively are going to write the exact same thing, only the line which contains F_PROFILE for you will have your heat flux bc.
use something like C_T(c,tc) to get the cell temperature while you are looping through all the cells.
hope that helps
Agi
Old   March 13, 2009, 14:46
shannag
Dear A Kourm, I am new fluent user, I will try it and I will let you know . Many thanks and kind regards Shannag
Heat transfer to the walls dmoroian OpenFOAM Pre-Processing 1 March 13, 2011 19:42
Use wall function on some walls (not all walls) Mahdi10 FLUENT 1 February 16, 2009 12:52
ratio of total heat flux and radiative heat flux S.Karthikeyan FLUENT 2 July 1, 2008 04:48
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 09:14
UDF: Function to Acces Shear Stresses at Walls daniel FLUENT 0 March 13, 2000 20:31
