Zero Heat flux at wall
Old   March 10, 2009, 13:18
Default Zero Heat flux at wall
Jules
Dear Friends,
Maybe you can help me. I have a 3d mesh with the outside walls being adiabatic and the inside walls not so. When I solve the integral for the total heat flux at the walls using rakes, I get zero for all of the walls.
I checked the properties of the walls, and only the outside walls are adiabatic.
Using FlUENT 6.2 Please reply if you can help; thanks. Jules
Old   March 11, 2009, 07:52
Default Re: Zero Heat flux at wall
Ben
While defining the boundary conditions you need to go for two different walls, one for inner one and second for outer one. Assign heat flux to the outer wall as zero, where as for the inner one make it as defalut. After making these changes run the simulation and u will find different wall flux for the inner one.
How can we get wall heat flux? Baheri Phoenics 0 September 19, 2007 07:23
heat flux in a wall Albert F. FLUENT 0 August 22, 2006 04:27
wall & wall shadow net heat flux Barbaros FLUENT 1 August 5, 2006 03:00
WALL HEAT FLUX tommy CFX 0 December 20, 2005 13:42
WALL HEAT FLUX V.S. HEAT FLUX tommy CFX 0 December 15, 2005 09:14
