Fluent simulation problem & Gambit "database"error
Old   March 10, 2009, 12:57
Default Fluent simulation problem & Gambit "database"error
Chase Estrin
Fluent:
I am running simulations involving a symmetric airplane geometry (only running sim. on half of the plane due to symmetry). I get through about 1500 simulations and look at the results and, on the plane, the only results that appear are near the edges. I am thinking maybe it is a problem with the volume being water tight.
Gambit:
I haven't tried to load my model for a few months now and got this error when trying to open it:
"Error: Unable to read format of database (version 2.4.4). The current format is version 2.3.14."
If anyone can help with either of my issues I'd greatly appreciate it. Thanks.
- Chase
Old   March 10, 2009, 13:26
Default Re: Fluent simulation problem & Gambit "database"e
Mandar
for gambit problem you can try to import the mesh from fluent that means import *.cas file in gambit
Old   March 12, 2009, 10:48
Jason
Gambit: Sounds like there might be a problem with your Gambit release. Sounds like you made the geometry in a newer version than you currently have... Not sure the fix. Check your with your IT guys on the Gambit version (current release is 2.4.6 from 2007)
Fluent: Sounds like a problem with your setup, need to give us more information. It shouldn't be a water tight problem, or you wouldn't have a volume mesh. Sounds like a boundary condition problem to me.
Jason
Old   February 21, 2013, 05:01
Default gambit .dbs file read error
EZHILMARAN
EZHILMARAN is on a distinguished road
i m also having the problem of reading gambit(2.3.14) file in gambit 2.2.14 version . i dont have 2.3.14 version so kindly help me
EZHILMARAN is offline   Reply With Quote
Old   February 21, 2013, 05:15
EZHILMARAN
help me to read new version of gambit(i.e 2.3.14) into old(2.2.14)
database dns simulation giacomo Main CFD Forum 0 September 23, 2008 05:09
ERROR in user-defined database materials Julien Lepaul FLUENT 3 April 16, 2008 10:13
How to change the material database for Fluent sxf FLUENT 1 May 3, 2005 17:37
internal database error pradeep sivakumar FLUENT 1 March 9, 2001 08:53
Gambit Journal File Scripts, Public Database Needed? Jonas Larsson Main CFD Forum 13 March 2, 1999 08:25
