Vortex shedding and aeroelastic flutter question
Old   March 7, 2009, 12:35
Default Vortex shedding and aeroelastic flutter question
Freeman
Hi all,
I was wondering if vortex shedding alternating pressures ober bluff bodies is the cause of flutter, for example in plane wings or oder slim objects, or aeroelastic flutter has nothing to do with vortex shedding. I'm a bit consfused...
By the way, is it possible to tackle the problem of aeroelastic flutter with Fluent, separately from NASTRAN or oder FEM codes? I mean, could the following (decoupled) approach of aeroelastic flutter be correct?
1. Simulate the unsteady flow over a wing. 2. Save every time step my pressure loads over the wing as a NASTRAN, ANSYS or whatever 3. Import these files into my structural FEM analysis software and saying to it that these are my fluctuating loads over the wing. 4. Calculate structure response to these fluctuating inputs imported from FLUENT and study if there is resonance, etc.
The problem is that I want to make a flutter analysis over an object (to see if it will be flutter or not on this object), but I don't have neither computational resources nor experience in coupling Fluent with FEM structural software...
Thanks in advance for your comments on this.
Regards, Freeman
Old   March 13, 2009, 07:45
Default Re: Vortex shedding and aeroelastic flutter questi
Luca
Hello! sure it is possible. Have a look at the publications on www.aero.polimi.it/~cavagna Hope this helps you a little. Regards Luca
Old   March 20, 2009, 08:19
Freeman is on a distinguished road
Originally Posted by Luca
;157388
Many thanks Luca. I read some of your abstracts and I found them quite impressive. But the question that comes to me now is that if it is possible to make FSI with FLUENT and, let's say NX-NASTRAN (FEMAP), without coupling. In our office we don't have MCPP or similar software for coupling, nor computational resources (and know how) to carry such simulation.
Could you shed me some light about this? Roughly write some lines in order to do FSI de-coupled, as my wing is quite small and it is expected not to exhibit arge deformations?
Thanks you in advance. Regards,
Freeman
Freeman is offline   Reply With Quote
vortex shedding Al Mazdeh CFX 0 March 19, 2008 10:49
vortex shedding Altug Basol Main CFD Forum 5 March 9, 2007 17:39
Vortex shedding Tony Main CFD Forum 2 October 7, 2004 13:01
vortex shedding Chetan Kadakia FLUENT 3 April 4, 2001 14:48
vortex shedding mahmoud Main CFD Forum 2 August 12, 1999 12:42
