Iterations
Old   March 5, 2009, 21:53
Default Iterations
Maple
Is it possible to continue the iteration process?.....
For example, after, say 20 iterations I saved my data today, can I start from 21st iteration tomorrow and continue the process?
Please let me know if i can do that in Fluent. Thank you very much.
Old   March 5, 2009, 23:51
Default Re: Iterations
Ganapathy
of course ! you can
Old   March 6, 2009, 04:20
nil
If you don't initialize, you can continue.
Old   March 6, 2009, 09:05
Maple
Please could you tell me how I can do that?....First, I will "Read" the case and then "Īterate". I should not "initialize"?
Would it start with the 21st iteration?
Old   March 6, 2009, 12:01
Maple
I tried it and it worked. Now I am able to continue the iteration process from 21st iteration.
I saved the first 20 iterations with the file name "study.dat". If i want to save the data (e.g., 1 to 50 iterations), should I use the same file name 'study.dat'?
or if i overwrite, would I be able to save the data (for 1 to 50 iterations)?
Old   March 6, 2009, 13:44
Ganapathy Iyer
/file read-case-data abc.cas.gz iterate 20 /file write-case-data abc1.cas.gz /file read-case-data abc1.cas.gz iterate 500
Old   March 6, 2009, 13:47
Ganapathy Iyer
If you overwrite you will still have 50 iterations data
Old   March 6, 2009, 13:57
Maple
Thank you so much.
UDF of iterations h6h6 FLUENT 4 August 29, 2018 00:07
Iterations Jorge A FLUENT 0 September 6, 2007 14:24
iterations suailek FLUENT 0 July 30, 2004 06:56
Sub-iterations - What do they mean? Arun FLUENT 0 May 18, 2004 15:37
Iterations + more Steve Main CFD Forum 1 March 23, 2004 13:18
