same Drag Coefficient
Old   March 5, 2009, 11:28
Default same Drag Coefficient
Amir
I'm modeling a turbine ventilator Which looks like a backward centrifugal fan. In this case I run simulation for 5 different speeds from 7 to 25 meter per second which correspond to Reynolds numbers of approximately 6.8*e04 to 1.9*e05 and rotation speeds of 230 to 850 rpm.
For all the mentioned cases I got the approximately same drag coefficient of 0.44. also lift coefficient are also same. It doesn't match to experiments which shows the drag coefficients decrease by increasing the free stream velocity.
I double checked the reference values.
I wonder if its about the induced drag!! or something else.
Any comment is well appreciated.
Regards, Amir.
Fluent Good Lift coefficient BAD drag coefficient Rif Main CFD Forum 4 March 9, 2010 11:52
drag coefficient puneshwar verma FLUENT 2 February 28, 2007 01:04
drag coefficient valentina FLUENT 2 January 23, 2007 14:16
coefficient of drag C.Mohan FLUENT 1 January 8, 2007 14:00
about the drag coefficient maximus Main CFD Forum 7 April 18, 2005 20:00
