March 4, 2009, 11:36 |
how to do parallel simulation
Guys! My computer is 64-bit with 8 processors. The OS is Windows XP. After I opened Fluent, type in " fluent 3d -t4" in the commmand line, error message comes out, which says "invalid command". Does anyone tell me what is the mattter? how to fix the problem? Thanks in advance. Jiuan |
March 5, 2009, 00:16 |
Re: how to do parallel simulation
Try this
c:\fluent.inc\ntbin\win64\fluent.exe 3d -r6.3.26 -t4 -mpi=default -awin64 |
March 5, 2009, 10:58 |
Ganapathy is right.
In order to use "fluent -t4" you must add the destination of fluent in your PATH variables and it will work just fine! |
A parallel simulation problem in DPM | satum | FLUENT | 0 | October 21, 2008 05:38 |
How to run parallel simulation on PC with two-CPU? | Jimmy | FLUENT | 1 | July 14, 2008 00:46 |
Parallel Simulation using Star-CCM+ | SG | Siemens | 5 | March 11, 2008 10:52 |
How to run a parallel simulation? | J.Gimbun | FLUENT | 9 | May 24, 2006 05:47 |
Parallel simulation of unsteady flows | MLJ | Main CFD Forum | 5 | June 14, 2000 01:24 |
