April 5, 2011, 17:54 |
#21 |
Hooman
Rep Power: 15 |
Any help please?!
April 8, 2011, 09:27 |
#22 | |
Vipul
Rep Power: 15 |
What K-E model are you using? I have found that Realiazable is the best. Also what sort of wall treatment are you using? If it's standard wall funtion you want to aim for y+ values of greater than 30. If it's enhanced wall function you need your y+ to be less than 1, which means you will need a very fine mesh at the wall.
April 8, 2011, 12:23 |
#23 | |
Hooman
Rep Power: 15 |
April 8, 2011, 12:56 |
#24 | |
Vipul
Rep Power: 15 |
Your Y+ values should be corresponding to your wall ONLY. If you are using Standard wall function for KE - Aim for Wall Y+ values between 30 and 150 at the wall.
Search for an article "Wall Y+ Strategy for dealing with wall bounded turbulent flows" by Salim M. Salim and S.C. Cheah - It is a very good paper. Email me on vh00011@surrey.ac.uk - if you can't find the paper and I will send it you. Quote:
January 12, 2012, 21:22 |
Journal Article on Wall y+
#25 |
And the corresponding journal paper is titled "Wall y+ approach for dealing with turbulent flows over a wall mounted cube" published in "Progress in Computational Fluid Dynamics" by Inderscience.
http://inderscience.metapress.com/co...0284130n05742/ |
January 14, 2012, 01:52 |
#26 | |
Lucky
Rep Power: 66 |
September 21, 2016, 00:52 |
Y plus For Water Enclosed in Insulated Chamber and getting heat from Top of Chmaber
#27 |
Bk
Rep Power: 10 |
Hi is it really need to make boundary layer for Water Enclosed in Chamber and getting heat from top of the chamber. as pressure is atm. and air velocity inside is negligible at initial but as temp goes up there is increase in velocity.
So how do i calculate Y plus for it? |
February 3, 2018, 10:01 |
I dont know how to deal with this
#28 |
anonymous
Rep Power: 8 |
Hi, I am using a spallart allmaras model to run an external aerodynamic flow on a naca 0012 wing with 0 angle of attack. The Y+ values is between 0 and 8, which is not ideal. However, when i changed to the K-epsilon model, i get my wall y+ value to be between 0 and 1. However, the residual in K-epsilon and Spalart is vastly different. Has anyone here encounter something like this?
February 4, 2018, 10:47 |
#30 |
anonymous
Rep Power: 8 |
Hi far,
Thanks for the reply.. Since its normal, do i try to get both between 0 and 1? I am uncertain in what i should do |
February 4, 2018, 10:52 |
#31 |
in both cases, the Y+ should be below 1 if you want to resolve the sublayer.
since both model will calculate the friction velocity differently and hence different Y+. I would recommend to create Y+ value below 0.5 to get the Y+ below 1 for both models. |
February 4, 2018, 10:59 |
#32 |
anonymous
Rep Power: 8 |
Thanks alot far!!
Really appreciate the advice since i am new to this Guess that i am back to it then |
can any one correct this(udf) | solomon | FLUENT | 5 | December 5, 2007 02:24 |
Is this correct? | Siva | FLUENT | 3 | August 14, 2007 09:35 |
to correct me an udf program | farida hamadi | FLUENT | 0 | December 18, 2004 06:54 |
Is this UDF correct? | JJ | FLUENT | 3 | April 8, 2001 19:54 |
Result is not correct | Li | FLUENT | 1 | December 30, 2000 01:21 |
