Errpr on Post processing
Old   February 26, 2009, 14:53
Default Errpr on Post processing
Murat
I created 3D domain then I converted it to polyhedra meshing to be able open it in workstation. Then, i started to solve it in Fluent. But, when i want to see the postprocessing of the result, there seems nothing on computer screen and error message seems like: 'Cortex received a fatal signal(segmentation violation)'
What can be the reason for this problem? I tried to see contours, vectors but only black screen appears.
Thanks,
Murat
Old   February 26, 2009, 19:00
Default Re: Errpr on Post processing
Murat
The error Message are seen on the Fluent command Line.
Old   February 26, 2009, 22:10
raj
did u "scaled" properly and did "grid checking"?? and give the correct operating and boundary condition??
Old   February 27, 2009, 01:16
Default Re: Error on Post processing
Murat
I did all face and volume mesh checking but gambit did not find any problem. Interesting and unknown part is that i tried the same .msh file without using workstations (parallel processing)and i could see the all post processing results of the solution. i do not know why fluent gives such an error on parallel processing, although there is no error without using parallel processing.
Thanks,
Murat
Post Processing in v3.5 Short Phoenics 5 March 16, 2005 05:51
3D post-processing Natalie FLUENT 3 August 11, 2004 06:13
Post Processing D Harvey FLUENT 0 May 24, 2004 22:37
Post Processing in FEM Abhijit Tilak Main CFD Forum 0 April 26, 2004 12:59
Post-processing Eric FLUENT 0 April 19, 2004 11:17
