bc/wall/thermal - temperature not-constant?
Old   February 24, 2009, 18:29
Default bc/wall/thermal - temperature not-constant?
martin
(fluent 6.3.26)
I'm looking for a way to calculate heat transfer to a wall including the rise of the wall temperature (unsteady). The case looks like that:
adiabatic isolation | aluminium wall (0.01 m) | fluid (0.1 m) | aluminium wall (0.01 m) | adiabatic isolation
The fluid will become hot so it should be cooled by the wall. The wall should become warm (a little bit).
In temperature-mode the wall-temperature is constant. In Heat-Flux I don't see a way to set the initial wall-temperature. I tried adding a bunch of "solid" cells but this won't solve the problem as adjacent zones can't have different materials.
Also "Users Guide - 7.13.4 Heat Transfer Calculations at Wall Boundaries" omits wall thickness for all options so I have no idea what to do.
Old   February 25, 2009, 04:42
Default Re: bc/wall/thermal - temperature not-constant?
Ashish
i think u should explain problem a bit more i assume that "fluid is getting cooled as it loses heat to walls"
how you are defining it in terms of bc, can u explain pls ?
Old   February 26, 2009, 07:39
Ralf Schmidt
Hi!
The thickness of the wall does NOT have any meaning for cooling problems!
You have to define two domains: one fluid and one solid. With a SINGLE wall between them.
Now, you set the initial temperature: solve - initialize-patch. Select the solid and patch the temperature you want.
The BC for the wall between fluid and solid (both: "wall" and "wall-shadow") is coupled.
(you have to consider the other BC for the other sides of your solid)
Thats it!
Best wishes Ralf
Old   February 26, 2009, 10:20
martin
thanks, that's not what I wanted to hear but at least now I know how to make it work...
Old   February 26, 2009, 10:30
martin
I tried setting wall temperature to 300 K. Now the (hot) Fluid will become cooler but the wall temperature won't change. So after some (infinite) time everything will be at 300 K instead of some (higher) mixing temperature.
In the other message Ralf told me, walls have no variable Temperature. I need a row of solid cells and a wall between fluid and solid to do that.
Old   March 1, 2009, 12:33
phiz
I'm trying the same for a pure conduction problem only for solids, so no fluids are present. I was wondering, if I would use patch, would the other wall boundaries not apply? (I don't want to give in any, for I need Fluent to calculate these). So basically my question is what patching really means
Please review: http://www.cfd-online.com/Forum/fluent.cgi?read=64337
Thanks in advance
urgent: Combustion constant temperature Tim Siemens 3 June 29, 2008 19:12
Constant temperature boundary Ananta Phoenics 3 June 5, 2008 10:24
heat transfer with constant wall temperature Marco FLUENT 0 December 8, 2005 08:16
Constant wall heat flux with uniform temperature Jake FLUENT 2 September 29, 2003 12:34
transient temperature field with constant velocity Törnquist CFX 0 September 16, 2003 05:22
