heat transfer with porous media
Old   February 24, 2009, 14:43
Default heat transfer with porous media
gokul
my problem was air heater heat transfer with porous.it is have multi blocks each block have same tubes.am give a each block for same porosity for inertial co efficient C2(1/m) and volumetric heat transfer rate(w/m3)and density correction. in this case the the reduced correctly but the density also reduced.
i have a doubt for which one best method for porous media heat transfer in fluent? i am using polynomial method but it will not given proper solution.if any viscosity correction need for that problem? or constant viscosity is enough? any other method to solve my problem?
Heat transfer within Porous Media Twiti CFX 10 January 15, 2021 09:13
REG POROUS MEDIA HEAT TRANSFER Rashmi Venkat FLUENT 6 June 1, 2006 06:13
Porous Media with heat transfer A.S. Siemens 2 February 23, 2005 04:01
Heat transfer in porous media Sri FLUENT 0 January 16, 2002 23:54
heat transfer in porous media Jörg Brozio FLUENT 1 March 29, 2000 00:17
