Changing Heat transfer coefficient
Old   February 24, 2009, 07:05
Default Changing Heat transfer coefficient
Ashish
I want to solve a transient conduction problem in which one wall boundary condition is defined in terms of heat transfer coefficient. As time passes heat transfer coefficient will change with respect to avg temp of that wall.(so i want to correlate avg temp of wall at the end of each time step to the heat transfer bc)
: > help
Thanks in advance.
Old   February 24, 2009, 07:25
Default Re: Changing Heat transfer coefficient
Ralf Schmidt
go to
solve->monitors->surface
and set one surface monitor each time step for area weighted average Temperature at the wall and one surface monitor for area weighted average HTC.
Best wishes Ralf
Old   February 24, 2009, 07:51
Ashish
Thanks for help
BUT I THINK I FAILED TO COMMUNICATE- one of the thermal bc for conduction is HT coefficient and T ambient which will remain constant (there is only constant option in drop down menu next to it). But HT coefficient itself is a function of avg wall temp. (which is changing as i am solving transient problem) So i want to teach code to take avg wall temp at the end of first time step put that into some formula and put the newly calculated HTC as bc for next time step and so on
thanks
Old   February 24, 2009, 08:02
Default (PROBLEM IS UNSOLVED) *NM*
Ashish
Old   February 24, 2009, 08:08
Default Re: (PROBLEM IS UNSOLVED)
mange
I think you have to code your function as a UDF. DEFINE_PROFILE i think should do the job. this way you can specify h as a function of whatever you want.
/M
HELP: How to get Heat transfer Coefficient? Benny FLUENT 4 June 6, 2005 12:42
UDF - Heat transfer coefficient kulasekharan FLUENT 3 August 12, 2004 08:09
heat transfer coefficient Jorge Facao FLUENT 0 June 4, 2004 17:35
Fix the heat transfer coefficient Karin Phoenics 1 May 19, 2003 06:21
heat transfer coefficient Peter Main CFD Forum 7 August 26, 2001 19:44
