February 24, 2009, 01:35 |
error in loading valve.c of dynamic mesh
Hi all
I tried to solve dynamic mesh (valve) problem in fluent6.3.26. while I am loading the UDF (valve.c) it is showing an error massage like below. " Deleted old libudf\win64\2d\libudf.dll 1 file(s) copied. (system "copy C:\Fluent.Inc\fluent6.3.26\src\makefile_nt.udf libudf\win64\2d\makefile") 1 file(s) copied. (chdir "libudf")() (chdir "win64\2d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file. Done. "c:/documents and settings/tb13073/desktop/dynamic_mesh/dynamic_mesh" Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: ()" please give me the solution for this error, Thanks and regards, Pavan Kumar. |
February 24, 2009, 03:15 |
Re: error in loading valve.c of dynamic mesh
Dear Pavan
It seems ur UDF is having a problem reading the library 'udf.h' check ur C program most of the errors associated with UDFs compilation are syntax errors feel free to ask any doubts Regards Rishikesh |
February 24, 2009, 03:56 |
Hi Rishikesh,
Thankyou very much for your replay. The thing is I am not much aware of C code. If you have the code for this problem please send it to my mail ID: yours.pavan@yahoo.co.in Thanks and regards Pavan. |
February 25, 2009, 00:21 |
no man
i do not have the code u can check up which macro they hv used for the UDF. u can also go through the Fluent 6.3 UDF manual its avaliable on the net in PDF format Regards Rishi |
February 25, 2009, 00:22 |
no man
Fatal error whilst loading an icem mesh | Simon Mizzi | FLUENT | 0 | February 28, 2009 16:55 |
Dynamic mesh error | samnetmoon | FLUENT | 0 | May 19, 2008 12:45 |
Dynamic mesh error | Sham | FLUENT | 2 | June 13, 2007 04:23 |
ERROR WHEN ITERATING in dynamic mesh | bijan | FLUENT | 0 | June 10, 2006 03:11 |
ERROR WHEN ITETATING in dynamic mesh | bijan | FLUENT | 0 | June 7, 2006 05:53 |
