Conjugate heat transfer with periodic boundaries
Old   February 23, 2009, 10:51
Default Conjugate heat transfer with periodic boundaries
Suresh
Hi
I want to simulate conjugate heat trasfer Analysis of motor having both stator and rotor with heatsources, so i modeled 45 degree sector for the analysis with nonconformal rotational periodic interfaces. Multiple reference frame model was taken for rotor stator domain interface. The flow simulation (without any solid regions) was converged and got reasonable results but not getting realistic results when i included conjugate heat transfer method. I had taken around 400 Watts heat source for the solid parts. From the residual converging plot, its showing energy equation was converged but getting only 5-10k tempertaure difference for the whole domain global range.
I have some queries regarding my analysis
1. Is it possible to solve conjugate heat transfer with rotational periodic interfaces in Fluent.
2. If so, What are the boundary conditions for the periodic interfaces of the solid region
Please help me for this.
Thanks in advance Suresh
conjugate heat transfer amar FLUENT 1 February 11, 2009 10:04
heat transfer in conjugate heat problems cirilo Siemens 1 April 18, 2006 10:16
Conjugate heat transfer (vs) periodic boundary mp FLUENT 1 January 13, 2003 02:38
Conjugate Heat Transfer A. Roy Phoenics 1 June 26, 2002 19:35
Conjugate heat transfer Lu Zhang Main CFD Forum 2 July 19, 1999 16:37
