Gambit Default Working Directory
Old   February 21, 2009, 23:16
Default Gambit Default Working Directory
Virgil Howardson
How can I change the default working directory in Gambit? It is currently set to "./" which won't point to anything. Ideally, the default working directory would be the directory in which Gambit was opened in. I am using the Windows version of Gambit 2.3.16 with Hummingbird Exceed.
Old   February 23, 2009, 08:12
Default Re: Gambit Default Working Directory
mAx
On Gambit Icon, right click, choose properties, and fill the path you want in "Execute in"
Old   December 11, 2009, 21:41
Saeed Abbasi
sabbasi_mr is on a distinguished road
Hi, I have the same question. I did it, but it doesn't work.
sabbasi_mr is offline   Reply With Quote
Old   December 13, 2009, 17:29
JT.Q
jiangtao167 is on a distinguished road
Originally Posted by Virgil Howardson
;156769
hi Howardson
u can change the default working directory on start panel.when u start G. ,u will see the panel as attachment 1,which in the working dictionary is the drive/folder you open,then press browse button and chose the drive by drives pull down menu(here e:/ as an example),then click the folder listed above(folder fluent as an ex.) as show in 2,then click ok button.you will see the working directory being changed as 3. also you can change the file name in session id box as a new tour,here 3d as an ex. or by pulling-down the session id list and chose an exist one to continue ur work.
hope its helpful
jiangtao167 is offline   Reply With Quote
Old   December 18, 2009, 22:53
Question Gambit 2.3.16, Xming or Exceed...
bambam3417 is on a distinguished road
Ok so I have windows 7, and I am trying to run Gambit I have Fluent 6.3.26 and it runs beautifully!!! but Gambit says the usual for many people:
Locating Exceed installation ...
gambit failed in locating Exceed installation on your system.
Please try to start Exceed manually before you run gambit.
Starting C:\Fluent.Inc\gambit2.3.16\ntx86\gambit.exe -device open -id default_id2352 -new ...
Gambit build SP2006032921.
Warning : The current transport does not permit the attempted TCPIP connection.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/bam-bam:0
Unable to open display
SO I DOWNLOADED XMING WITH ALL ITS ADD-ONS AND STILL CANT GET GAMBIT TO WORK NOT EVEN WITH THE -DEV X11 COMMAND ON OPTIONS SO I WAS WONDERING IF ANYONE CAN HELP ME TO INSTALL XMING WITH GAMBIT OR TO TELL ME WICH VERSION OF EXCEED WILL WORK WITH MY GAMBIT ANY HELP WILL BE REALLY APRECCIATED!! I NEED GAMBIT TO COMPLETE MY INVESTIGATION
THANX IN ADVANCE GUYS!!
bambam3417 is offline   Reply With Quote
Old   December 19, 2009, 07:13
ck3
Khaled
ck3 is on a distinguished road
what is your exceed version? because win vista and win 7 axcepte only hummingbird exceed 2008 version.
ck3 is offline   Reply With Quote
Working directory via command line Luiz CFX 4 March 6, 2011 21:02
ICEM working directory setting Bogesz CFX 2 October 8, 2008 08:45
Star-CCM+ Set Working Directory Bart Siemens 1 September 1, 2005 02:01
setting the working directory Jiri Novak FLUENT 4 April 24, 2005 09:13
GAMBIT default parameters?? JB FLUENT 3 January 28, 2005 09:50
