libudf error: undefined symbol:
Old   February 18, 2009, 20:16
Default libudf error: undefined symbol:
Prashanth
I am compiling an UDF for a particle deposition study. I am getting the following error though my UDF gets compiled with just a few warnings and no error.
Opening library "libudf"...Error: libudf/lnamd64/3d_host/libudf.so: undefined symbol: dpm_scalupError: libudf/lnamd64/3d_node/libudf.so: undefined symbol: dpm_scalupError:
Primitive Error at Node 0: open_udf_library: no error /nfs/14/osu5206/.bashrc: line 1: module: command not found
I am posting my UDF below. Please let me know if Im missing something. The same UDF was compiling perfectly and the library was also loading yesterday. I just changed some parts of my code to comments and now Im having this problem.
#include "udf.h" #include "dpm.h" #define nu_s 0.27 #define nu_p 0.27 #define YMIN 0.0 #define YMAX 0.4 #define UMEAN 1.0 #define B 1./7. #define DELOVRH 0.5 #define VISC 1.7894e-05 #define RGAS (UNIVERSAL_GAS_CONSTANT/MW) #define Tdatum 288.15
/*Domain *domain; /*Get domain pointer and assign later to domain*/ /*int UDM_checked = 0; /*availability of UDMLs checked*/ /*void reset_UDM_s(void);
DEFINE_DPM_BC(deposition_bc, p, thread, f, f_normal, dim) { real crit_vel,alpha,Tavg,Ep,vcr; real norm_coeff=1.; real tang_coeff=1.; real vn=0.; real R=287.; Thread *t; real normal[3]; int i,idim=dim; real Cu,cbar,lamda,kn; real Wa = 0.039; real x[ND_ND];
for (i=0.; i<idim; i++)
normal[i] = f_normal[i];
if(p->type==DPM_TYPE_INERT)
alpha = M_PI/2. - acos(MAX(-1.,MIN(1.,NV_DOT(normal,p->state.V)/ MAX(NV_MAG(p->state.V),DPM_SMALL))));
if ((NNULLP(t)) && (THREAD_TYPE(t) == THREAD_F_WALL))
F_CENTROID(x,f,t);
/*computing normal velocity*/
for(i=0.;i<idim;i++)
vn += p->state.V[i]*normal[i];
/*computing critical velocity*/
Tavg = (F_T(f,t)+P_T(p))/2.;
Ep = (3.*(pow(10.,20.)))*exp(-0.02365*Tavg);
vcr = pow(((2.*Ep)/P_DIAM(p)),(10./7.));
int cntr=0.;
/*particle continues its path - no sticking*/
if (vn > vcr)
return PATH_ACTIVE;
else
F_UDMI(f,t,0) += P_MASS(p); /*mass of particles deposited*/
F_UDMI(f,t,1) += 1.; /* No. of particles deposited*/
return PATH_ABORT;
/* DEFINE_ON_DEMAND(reset_UDM) { domain = Get_Domain(1); reset_UDM_s(); }
Old   February 20, 2009, 08:50
Default Re: libudf error: undefined symbol:
mange
it seems you do not have matching /* */ . try to remove that first comment line.
/m
Old   February 20, 2009, 10:59
Default Re: libudf error solved - SEGMENTATION ERROR now
Prashanth
Hi
Thanks for the reply. I did take out all my comments and try the code as it is. It compiled perfectly without any error but when I run the case with my UDF as my wall boundary condition, I get a new error as follows:
Stack backtrace generated at node 1. Report bug to administrator. Process violation at node 1: Segmentation error
How do I get around this error?
Old   February 20, 2009, 11:08
mange
if you run in parallel you need to put
#if !RP_HOST #endif
around your code. because the host process does not have access to the data.
/M
Old   February 24, 2009, 20:04
Prashanth
Hi
I included the above mentioned commands in my code. Now I'm getting the same SEGMENTATION ERROR with additional message before it as below:
Stack Backtrace Generated at node ... of process id.. Please include this information about the bug when you contact administrator.
What does this mean? I'm really at a dead end right now as I have checked and re-checked my UDF and it seems to be right. Please let me know your thoughts. I can send you my UDF if that would help.
Old   July 28, 2010, 08:03
Default a way out of this problem
ahmad
almostafa67 is on a distinguished road
if u have some errors in ur udf,FLUENT will show this error,I used FLUENT 6.3 to compile my udf but i faced this error,And i could not get rid of this error till i used ansys 12.0 and ansys showed me that i had some syntax error in my udf, i corrected them then compiled udf,and eventually thank GOD it compiled without any error.
almostafa67 is offline   Reply With Quote
Old   August 22, 2019, 01:24
Allen_ayt is on a distinguished road
Hi!
I also came across the same problem, so how did you solve the 'undefined symbol' problem in parallel condition?
Thanks!
Allen_ayt is offline   Reply With Quote
OpenFOAM 15 libreadlineso5 undefined symbol PC frafridr OpenFOAM Installation 0 February 3, 2009 20:37
Error with posdat.f - undefined symbol: for_open Emmanuel Resch Siemens 2 August 20, 2007 16:46
Symbol lookup error in 14 that was not present in 13 adona058 OpenFOAM Bugs 1 July 25, 2007 17:04
undefined symbol Dario Nexus FLUENT 0 October 12, 2006 08:54
error setting up libudf andrew_garrard FLUENT 4 August 19, 2003 11:17
