February 18, 2009, 05:11 |
radiation module, no accuracy result
I'm modeling a radiation problem. In my model, I have some lamps hanging above a substrate. I give a pre-determined temperature to the lamps and want to see the radiation distribution of these lamps on my substrate. I use gambit to set out the model and mesh the models. I mesh the volume with Tet/Hybrid Tgrid type and set the interval size to 3. After setting my boundary conditions, I get a very large mesh file, about several hundred MBytes.
I use DO radiation model in fluent, and set theta divisions and phi divisions to 10 and use parallel mode. After a very long time calculation (3days), I get my results. However, the results which is the radiation along a side of substrate are not smooth at all. And I find the result is very different from that when I set the volume mesh size to 6 (which requires a shorter time but shows rougher data). Could you tell me why this happens and give me some advices for meshing my model? Thanks very much for your help. |
MHD Module | Ashish | FLUENT | 2 | November 18, 2017 04:40 |
VOF module in CFD ACE+ | Huang | Main CFD Forum | 1 | September 19, 2006 15:27 |
Radiation Module using discrete beam method | Vipul Jain | Main CFD Forum | 1 | May 2, 2006 10:32 |
Cavity air flow with radiation – result variable | Yingchun | CFX | 1 | November 25, 2005 12:13 |
MHD Module | Benny | FLUENT | 0 | March 16, 2004 06:04 |
