hi all i am getting a negative volume in an unsteady state simulation of a bearing air-gap. i am using a cg motion udf for a shaft.
whats the remedy? |
Dear Rishikesh Try to use smaller time step size. Regards. Mustafa Ayad
smaller time steps would work but after some iterations it would again come with negative volume so just check your mesh and also the geometry before u do the problem..but try using smaller time steps it would work atimes.. regards hari
Negative volume | Mahbub | Siemens | 7 | April 28, 2011 08:04 |
Negative Volume in CFX | Barbara | CFX | 2 | January 10, 2008 10:19 |
negative volume | Avesta | FLUENT | 2 | June 19, 2004 06:34 |
Negative Volume | sen | Siemens | 2 | January 18, 2001 23:43 |
negative volume | Sabatini | Siemens | 4 | October 26, 2000 10:07 |
