Gear Pump solution
Old   February 13, 2009, 18:44
Default Gear Pump solution
Mustafa Ayad
Dear All I make a 2D simulation of gear pump as you know the two gears rotate with 2000 RPM ie 33.33 RPS and the boundary condition for inlet is 30 PSI and 3500PSI for outlet my problem that when i do the iteration of my case to 100000 time step and MAX number of iteration per time step is 1 to get 1 sec. because my time step size is 1e-5 then when i finish the iteration (take 12 hour to finish ) the velocity vector appear from outlet to inlet is that correct this is the first ,2nd that is this correct " in gear pump simulation the gear teeth should not touch each other" Thanks Mustafa.
Gear Pump Elian81 CFX 5 August 1, 2012 19:50
gear Pump elia81 CFX 5 June 2, 2010 19:36
C.G of Gear Pump Mustafa Ayad FLUENT 0 January 23, 2009 15:53
Gear pump simulation Vidyaprakash Siemens 1 December 12, 2008 23:44
Simulation of a gear pump? Peter Specht FLUENT 4 October 29, 2007 02:25
