February 11, 2009, 13:19 |
flux through individual cells / face areas
I'm trying to calculate total Q through individual cells in a 3D model. I initially tried multiplying Vx, Vy, and Vz by the respective face areas (x, y, and z) as a Custom field function. There seems to be a problem with the calculated face areas calculated in Fluent, as for many faces all 3 face areas this value is zero. Does anyone know a better way to calculate flux through an individual cell or has anyone had a similar problem with the face areas? (I have also used x, y, and z surface areas and achieved the same result)
February 16, 2009, 02:20 |
Re: flux through individual cells / face areas
Any comments on this?
February 16, 2009, 11:43 |
I'm still investigating this using UDF's...
Face areas affect scheme switching criterion for leastSquares | 7islands | OpenFOAM Bugs | 3 | July 4, 2008 03:40 |
selection of individual cells (not cell faces) | kamal | Siemens | 0 | January 17, 2008 02:00 |
use of face areas in flux function | Andrew Garrard | FLUENT | 1 | February 1, 2005 14:46 |
face areas UDF | Andrew Garrard | FLUENT | 0 | October 19, 2004 10:55 |
face loop over cells | Szabolcs Varga | FLUENT | 1 | October 1, 2004 00:18 |
